Hi everyone, I’m using studio one DAW with my SQ6, I was using a presonus mixer before that’s why. I installed the A&H driver to my PC, I was able to record my tracks, I did the same setup for the input channels on the DAW and it worked fine, my problem is that if I want to listen to my recording I have to switch the audio device on the DAW from SQ to windows audio and listen the recording on my headphones. When I set up the SQ6 as my audio device I can set the input without a problem, for the audio out it’ll show me that I have 32 channels available to route the L-R main mix outputs, I tried every single one, but I can’t hear anything, I tried routing every possible way on the I/O page of the mixer but I couldn’t get any sound to the speakers. I’m connected from my laptop to the mixer just through an usb cable. I hope someone can help me figure this out, tell me what I’m missing or what I’m doing wrong. I’ll appreciate any help. Thank you.
Hi Rober,
By default, SQ USB channels 1 & 2 are routed to the USB channel (found on layer B in the default setup).
If you set the main out to SQ 1 & 2 in your DAW, do you see signal on the USB channel?
Alex
