Hello,
My church is considering purchasing a SQ7 for FOH to replace our existing GLD-112. At the same time we want to add a SQ5 to a remote room for broadcast mixing for live streaming.
My questions are about the s-link technology. I see that we can connect the s-link ports together on the consoles and have 128x128 between them. Is there a distance limitation on the cat6 cable used to connect the consoles? Can the S-Link traffic be transmitted using standard ethernet network switches or do we need a dedicated run between the consoles?
If we use the s-link port in the sq-7 to connect to the sq-5 can we add a second s-link module into the sq-7 and connect it to our existing stage boxes? Do we require the second card or does the built-in port support both functions we want at the same time? Can the console handle have two s-link interfaces at the same time? Will we be able to setup routing to bring inputs in via stagebox/s-link and route them out to the sq-5 via a different s-link card?
I know Dante is another option, but there is also a cost premium with Dante.
Hi Ben.
Quick answers:
Yes, about 100m / 300 ft
Best to use a separate dedicated CAT5e (or better) cable.
Yes.
You will need an Slink card fitted in one desk.
Yes! (Not much point to the card if it couldn’t)
Yes, I suggest you look into the TieLines routing options.
If you want Dante in the future to connect something else, you could add a card to the second desk without disturbing to existing setup.
Hallo Benjamin,
adding to what MarkPAman said, I´ve made a video a month ago showing the routing for 2 SQs, Stagebox and extra Slink I/O optin card.
ROUTING 2 SQs for Live and Stream
Hope that helps a bit.
Cheers,
André
Thank you for the quick response and confirmations that we can setup in the way that I was envisioning.
Unfortunately the link the “ROUTING 2 SQs for Live and Stream” above is broken. The link doesn’t take me to a video. I would like to check out the video if you get a chance to fix the link.
@AndreS
The site name is missing. The rest of the link may be where at that site the info is at.
Or maybe that is what you put into google to find the answer
anyway clicking on the link gives this error message:
This site can’t be reached {{note: no http ???.??? / }} just:
if%20we%20use%20the%20s-link%20port%20in%20the%20sq-7%20to%20connect%20to%20the%20sq-5%20can%20we%20add%20a%20second%20s-link%20module%20into%20the%20sq-7%20and%20connect%20it%20to%20our%20existing%20stage%20boxes’s server DNS address could not be found.
