Wondering what the best practice is for routing with this system I’m configuring.
DM64 back stage with a gigaACE card to SQ7 SLink.
We have ME’s currently coming from the DM64.
Should I route from the MixRack I/O direct out to the SQ7?
Or should I use Tie Lines to pull from the stage boxes to the SQ7?
And then should I use Tie Lines to take the direct outputs from the SQ7 to the ME’s?
Or should I get another SLink card to put in the SQ7 IO Port, and use that for the ME’s?
There really is no right or wrong answer here. It really comes down to how you want to handle it.
Tie lines are used when you want to send audio from one device to another without processing/touching it at the device where you are sending/receiving the tielines. For example, if your stagebox is connected to the Mixrack, then it would be appropriate to use tielines to send all of the source’s audio from the Mixrack to the SQ so that the audio is sent to the SQ without it being processed/altered by the Mixrack. Those tieline would be routed into the SQ via the Slink port (ie it wouldn’t be called “tielines” at the SQ end, only the Mixrack end)
Direct Outs can be used to send audio out farther down the audio path. This way you can send audio to another device AFTER the audio is processed/modified by the “senders” end. You can select the pick point that is appropriate for the situation. If you wanted to send the processed “monitor” audio from the SQ back to the Mixrack to be further routed to the ME system, you would likely use Direct Outs at the SQ end and route them into the tieline inputs at the Mixrack end. You would further route that audio by sending the tieline inputs to the ME outputs - thereby routing the audio through the Mixrack without that audio actually appearing on a Surface or being processed by the Mixrack.
Now that being said, you could purchase another SLink card for the SQ and connect the ME system directly to the SQ instead of the Mixrack. That would simplify the ME audio routing, but ultimately it would provide exactly the same results (with perhaps a tiny bit less latency than having to send it to the Mixrack first).
In addition to there being slightly less latency than looping them through the MixRack, plugging the MEs directly into the SQ7 would make it easier to troubleshoot any issues since the audio wouldn’t go through anything else between the SQ and MEs.
I like systems being as independent as possible, so that’s the route I would take. It obviously costs more though, and sometimes there just isn’t the budget to do things the way you want to… otherwise everyone would be using DM64s w/ S7000s and analog splits for everything.
@jonathanhatch Can the tielines be set to multiple locations. If so, then send the tielines to the ME units and also to the SQ. What is the actual purcpose of the SQ in this set up? Is it operating floor monitors or running broadcast or something different?
