SQ7 - Lost FX1 Return From Surface Layer B
Hi all, would appreciate any ideas how to solve this problem. Recently and after loading a Dynamic Pack add-on into our SQ-7 we lost the FX1 Return channel from Surface Layer B. The channel is now blank and despite repeated attempts in Setup to activate or load it again it will not reappear on Layer B in its usual default position. FX2, FX3 & FX4 channels are all functioning correctly.
Selecting the FX menu and opening FX1 showed it is still passing signal and the back panel indicates FX Mode as FX>Return #1.
IIRC I might have mistakenly selected FX1 instead of FX5 as an insert during installation of the Dynamic Pack.
Any suggestions most welcome and many thanks in advance.
Symen
Hi all, just a quick follow up to say we have resolved this problem by un-assigning the FX1 Return on the FX1 back panel and reassigning it as a “FX>Return” All good now.
Thanks.
Thanks for following up—it was exactly what I needed!
