The mic on channel 2 comes 2 out of channel 2 and 3 even when mic on channel 3 is powered down. If you turn mis 2 off and turn mic 2 on it comes through both channels also. I a different scene and still have the problem
Sounds like you have the input, mic 2 is connected to, se as mix external input on both channels.
I used my phone to send the prior message and it came out wrong. Let me try again. When mic 2 and 3 are turned on and you solo each mic the sound coming out of both channels is mic 2.
Would you mind explaining what you think it is in a little more detail.
Brian
This likely comes down to a routing problem. Either you have the same source selected on both channel 2&3 (Local input 2 for example, or SLink channel 2) or you have accidentally inserted the same source as channel 2 as an “Mix Ext In” source on input 3. In either case, a careful review of the input patching on channel 3 will likely uncover the problem.
