SQdrive WAV playback is looping
Hello,
I have a SQ5 and want to use the stereo playback in the SQ drive.
I have set all wave files as pcm, 24bit, 44.1khz.
When a wave file is played, the last 30 secondes are repeated when the wav file ends.
When you have 20 songs on a tumb drive.
The files are named 01. , 02. , etc.
What could cause this?
I have used several usb thump drives but on all the same problem.
On an earlier firmware version, it worked fine.
Thanks.
I had this same thing happen with just one file. Part way through (the 30 minute file) it started repeating audio, although the time on the display kept incrementing. It only happened with one file, and always happened in the same place. Copying the file to a new location on the external SSD fixed the problem, so I’m assuming it was just a corrupted file, and the copy process fixed it.
Geoff
