Don’t think you’ll need a driver for your purpose, just open TCP port 51325 and directly communicate with the Qu.
You’d only need such a driver if you prefer to use the Windows MME/WDM MIDI Api.
QuPad connections should go a different path, you already may have multiple iPads connected to the same Qu.
Hello,
I have finally successfully communicated between my PC and the QU-PAC
The communication is pretty simple reading / writing nrpn bytes directly from the TCP/IP stream
I have found few typos copy/paste errors in the qu midi documentation
I am parsing actually every messages and I don’t find in the pdf the signification of the NRPN with ID = 0x56
Do you have a most recent documentation ?
Do you know what is it?
I want to create a windows APP to control the QU-PAC
My first goal is to have all the QU tracks in ONE big screen, and not be limited to 8 tracks in the QUPAD app.
Also, showing the name of every aux in the aux selection buttons
Then will add more custom features like a button to momentary change my mic into a talkback mic in iems
And some PAFL combinations buttons
Maybe I will share my QU-MIX windows app here if someone interested
Well, latest version is here: Qu Mixer MIDI Protocol - Firmware V1.9+. NRPN ID 56h isn’t documented there either. When does this occur?
I guess there are several people very interested to have remote capability on a “regular” computer. If you’re right at a start I’d highly recommend to use some multi-platform environment like JUCE and not only focus on Windows.
A clever approach would include an offline version to, at least, name and pair channels with possibility to send that configuration to the desk later (when in reach).
It is with the Get System State Sysex message. I receive then tons of NRPN and 56h is one of them. (Maybe my parser error? I don’t think all is documented)
I am using .net and don’t know to program with c++ juce and multi platform…
So at last we will have a nice QU program for windows
While decoding this huge nrpn stream, I now understand a lot more my QU mixer and it is full of options
I only dream about having the AB168 extension for the QU-PAC so my program will really shine
With my app, it will be so much easy to mix but
Not sure if QU MIDI protocol can be as fast as the one used by the QUPAD app
Maybe the QUPAD app allow to have a better resolution than 0-127 for the faders?
By the way I have started to toy with this TCP possibilities.
We are 2 singers, and everyone will have a pedal
When we press the pedal, our microphone will become a talk back microphone.
It set ASSIGN = OFF the mic to the LR , AUX56 that are loudspeakers and to FX, but sets a special level to all the IEM auxes
Wow we are now free
The next cool thing will be :
I will do few big buttons for each AUXES with the name of the musician
When I select on aux, it will automatically PAFL it, so I can hear what he hear too in his IEM
As I like to PAFL the LR in my headphones, when I press LR, I will also PAFL the matrix 1-2 that will contain the " talkback " mic only
Then I hope to add 40 faders in one big screen, with colors etc …
@DanZ could you give me some starting support for the communication with a Qu-24. I’m looking for a way to program the scenes in a fast way. From the directors script I generate the table for the microphones, which needs to be open. (per scene a row) And this table I want to transfer to the Qu-24.
First idea has been to “decode” the storage file format (.dat files)
But if there is a chance to do so via MIDI or DAW, it might be the better way.
I did not found a MIDI command to store a scene.
So the work around might be a manual button push for every scene.
With 40 scenes it might still faster than entering every detail via the Qu-24 buttons.
@Danz As I can generate the table from the MS Word script, it would be fine to transfer the Mic settings to the Qu.
The Pad has a save scene function? I have not found it. But anyhow this would not transfer the table to the Qu. But would be good to know, that there is a remote way to save scenes.
I don’t know if it is possible to transfer scene files, but it is possible to send i.e. all tracks volumes one by one to the QU with some midi messages
