Start/stop instead of start/pause sofkeyoption
This is just a detail, but it would make my life easier if this gets updated. Maybe some of you have the same whish?
I use my cq18t for theater as an on stage musician. Regularly I use the USB playback function to play a recording, so I have start recording set under one of my softkeys. Pressing it a second time, pauzes the recording. I would need the option to press it, making the recording stop and go back to the starting point. So a start/stop option next to the start/pause would be really helpful.
The Record/Stop assignment for the soft key seems to do what you need, unless I did not understood correctly.
Thanks Frenchie,
What you are saying works for recording, but I’m playing back preloaded tracks from my usb stick. So I have the option to play/pause or record/stop.
I would be looking for a play/stop option, so the track goes back to the starting point. (without having to use two sofkeys)
OK I see now.
Indeed, I cannot achieved that with only one softkey and I see no solution.
That can can be done with 3 actions, Record/Stop, Previous and Play.
Did you considered the footswitch option ?
The footswitch might be the way to go indeed. I’ll try it, as I need the sofkeys for other stuff. Thanks for sharing your thoughts
Start/Stop as well as, not instead of Start/Pause!
