Ive also had the white screen hang happen before(approx 18 mths ago) - freaked me out as it was in the middle of a theatre season but thankfully after a restart it booted correctly. It may have been temperature related, or perhaps a network connection or boot order problem? Who Knows? That was with the original IDR48 main board which has since been replaced about a year ago.(A&H’s known Power supply fault caused failure) No probs since then
Cheers
Richard Howey
Audio Dynamite Ltd
I had this issue and a few other little annoying ones. I was instructed to do a reset which cured all of the annoying little issues I had. So far no lock up either.
Yes a reset of the touchscreen computer (SBC) should fix the white screen problem.
The white screen issue at boot up is caused by the SBC in the surface that runs the touchscreen not booting correctly, this can be temperature related.
First it would be good to establish which SBC is fitted to your T112. if you go to Utility - Firmware - Firmware version and look at the touschscreen it should tell you which type you are using.
if you have the Axiom Tech SBC you can press the reset SBC switch located on the back of the surface.
If you have a fujitsu SBC you will need to power cycle the surface.
If the SBC goes into a white screen and does not recover after a power cycle then please contact technical support who will be able to resolve you issue.
Might be worth mentioning that you can run the SBC software on an external laptop if you do have an SBC failure. At least you can see whats going on that way.
Yes you can run the recover SBC software on an external laptop in the event you do have an SBC failure.
This is included in the firmware package when you download it from the website. you will need to configure a PC laptop to be on a campatible and unique IP address. Run the DL5000SystemManager.exe and then when the connecion failed screen appears point the recovery SBC software at your surface and mixrack.
Note: this is recovery software only and not recommended to run along side the SBC in normal operation. Please use editor software for that purpose.
