Stereo Field / panning
I am sure there will be something simple I am missing but I cannot hear the stereo/ pan settings on the tracks from my DAW. I a using the QU32 with a iMac running UA Luna.
I am not sure what I’ve done wrong? if I listen back through the Mac monitors I can here the correct panning.
Please help I’m loosing hair here!
It sounds like the issue might be with the routing or monitoring settings on your QU32 or Luna. Double-check your output routing and make sure the stereo channels are properly configured for the QU32 to send the pan information to your speakers.
Double check the panning on the input channels on the console. If they are not stereo linked, they would each default to “center” panning which obviously would prevent you from hearing the panning of the source (iMac). Although stereo linking channels will generally cause them to be hard panned left/right, it is possible that this has inadvertently been changed too.
