Stereo linking and unlinking - possible bug?
I switch between a few different scenes through the week which have different output links engaged.
Lets say scene 1 has all mono outputs
Scene 2 has stereo linked on all (1+2 / 3+4 / 5+6)
So when I recall scene 1 after using scene 2 - firstly it’s not switched back to all mono.
When I unlink some data reappears like the names of the channels, auxiliary mix e.g. fader positions.
Some troubles though;
  1. The master fader disappears on whatever the second linked channel is sometimes on the output fader layer (aux 2, 4 or 6) so I can’t control the master volume or unmute the aux (this happens despite the auxiliary name reappearing on the mix selection tab on the right)
    I can get them back by loading another third scene in all mono and reloading scene 1 but not ideal.
  2. Scene 1 has different GEQ sets per send. When I unlink sometimes the second linked aux inherits the GEQ preset that the first had instead of the saved one.
This is messy in this scenario for example I run a sub with a crossover style GEQ on aux 5 (shelved off over 160hz or so)
Aux 6 is a mix to an in house system and has been rung out for that speaker set in a particular venue.
I’ve recalled this scene 2 after using scene 1 and had to unlink aux 5&6.
Aux 6 inherits the shelved EQ and I have to re ring the system to aux 6.
I can get around this and have now saved the GEQ’s I need in user banks but again, it’s not ideal to have to double check all this info every load.
Any bug fixes or similar experience?
Also any suggestions to mitigate?
I read in another thread perhaps having a dummy scene to load and perform unlinking aux’s between loading scene 1 and 2.
Hope this makes sense thanks!
A Scene stores all preamp, channel naming, processing parameters, send levels, FX units and parameters and Soft Key and Soft Rotary assignments.
Channels and OUT link are not saved.
