Video is often on a different power source so try using an isolating transformer or DI to electrically isolate the system’s earths.
I hope this helps
Sound and video were taken from same power distro, changing cables did not help, we even tried connecting to monitor mixer. Only thing that helped was as I changed stereo matrix to two mono matrixes. Physical outpits remained the same. So the failure was defenitely in iLive system.
I hope this helps
Pitk.
Jukka “Pitkä” Kurkela
Äänimaisema Oy, Finland
iLiveT80 / iDr32
where were you sourcing your stereo mix from? This seems highly unlikely, I use stereo matrix sends with no problem quite often
Run your own test to make sure where the problems occurs…I use both stereo and mono matrixes all the time (using them right now actually) and it all performs as expected…so, send measured audio signal from matrix stereo then from mono matrix either to a computer running recording software or other outboard box you own…what’s the result ? If the problem is still there then you should contact A&H support and submit a ticket…
