stereo monitor send
Does anyone know how the stereo aux sends work, so aux 1 select and turned to stereo, aux 1 out of stage box to Fischer amp stick and it doesn’t work with stereo, you pan a channel over on the desk and you loose one ear the send is stereo, the Fischer amp stick is in stereo, is it because I’m going in with xlr and not a stereo jack, thanks
Hi SPEVS,
it’s not because of the wrong XLR setting, it’s because you haven’t use the second output.
If you switch an Aux to stereo you have to patch (I/O screen) left AND right to the output socket.
What you have done is only to use one side of the stereo signal by using just one XLR cable in one Socket.
Does that makes sense?
BR
Sascha
