I’ve got IP 9/10 setup as a stereo input for a keyboard that we use all the time. We’ve had a new person join the band and their keyboard only has a mono output.
We have multiple volunteers using the desk and I don’t particularly want them changing the channel stereo settings.
What’s the best thing to do? Use another channel, for example, 11. Or can I use 9 without changing the stereo setting?
The config stereo settings are at a show level and I presume it’s these that you want to leave - so if you’re just going to mono temporarily/occasionally, you could continue to use that stereo channel, but set the ‘Stereo Image’ in the preamp section of the processing to either ‘L/L’, ‘R/R’ (depending on where you connect it) or ‘Mono’ (for a mono sum of both).
This is stored with scene settings, so you can have a scene or multiple scenes for this setup.
