Hello everyone,
Is it possible to set all channels to mono on the SQ5. I can’t switch channels 41/42, 43/44, 45/46, 47/48 to mono. I’ve already tried it in the setup under Mixer Config. Would be very grateful for help!
I just tried that with SQ Mix Pad running on my PC, and it works fine. I saved the show to a new file on an external SSHD, loaded an older show (from the external drive), and then the most recent one again. 41-48 are once again showing as mono inputs. I haven’t actually tried this with a console, but the editor seems to handle it.
Are you using an old version of the editor perhaps? I’m using ver. 1.5.0
Geoff
Now it also worked on the console. It wasn’t enough to just switch to the “Mixing config”, I also had to assign it via “Surface”. Thanks for the tip. I also prefer the app in some cases ![]()
