T80 / iDr32, GEQ flip to faders cause one fader (4th from right) to take wrong position when returning to levels layer. It also takes the wrong level. Pretty annoying
as the fader is assigned to master of aux send (monitors) and the level pops up 20 dB. I’m about to re-instal firmware (1.83) next week, but wanted to bring up the problem already.
it could be a fader calibration issue? A firmware reload would probably fix it if it’s a software calibration issue, if not it could be a physical hardware sensor
That’s not that simple…
We had a similar issue round here and still no real solution.
It was no hardware fault alone. The whole system is affected.
