I know you can already scope a bank in recalling with snapshots and/or safe it but on a cti1500 it would be great to be able to recall only certain layers.
For example have latter F as your “show” layout with what you need per song but having anything else recall.
Right now if you want to change anything in your “static” layers, you have to do it in each snapshot.
I don’t understand the request… every scene safes everything, always.
You need to block the recall of the parameters you don’t want to change.
There is no recall scope available.
Indeed it would be an improvement to set Layers recall safe, additional to the surface banks.
But you can use embedded scenes to recall saved layout settings that are set as you like/need it. Just block everything else.
And the DCA Spill feature together with the user keys is unbeatable.
You can change your layout on the fly with it. Just use the DCA to spill the needed channels over your layers.
You are able to spill unassigned channels to the layer with this method. Just add them to the DCA with the routing screen.
Yes. Allen and Heath needs to add granularity to the layer recall safe options. Having only “all” or “none” isn’t very helpful. There are actually a lot of elements like this (but of course I can’t remember any off the top of my head) that need to have granularity added.
