Strip setup won't save
A while ago I had my ilive r72 repaired due to some sort of screen-battery problem. basically the screen never started properly.
When I got it back the scenes hadnt been removed, the channel names and settings were ok BUT the strip layout were all out of order. so i fixed it but I cant get the strip setup to SAVE!
So every time I start the console now I have to configure the strip layout both in left and right bank. I have to make everything from LR to DCAs to FXs etc. “appear” in the strip section even if I save it.
I have looked into the scene saving settings but havent found a solution yet.
please HELP
thanks.
Have you checked the startup scene? It is possible that you have the system setup to recall a scene at start-up and that start-up scene is what is causing all your strip assignments to move.
-d
David Shriver
Director of Technical Operations
Email: david@rockportmusic.org
Shalin Liu Performance Center
37 Main Street
Rockport, MA 01966
No I haven’t! I didnt even know there was such a thing. I thought it always started up the last scene that was recalled or in action.
The scene recall is a new in that update I believe…
T112, T80, iDR48 (2), iDR16 all w/M-DANTE, Qu-16, PL10, MixPads, Editor
