Sub split on Qu16
Hi, I have a few days a QU-16 and wanted to know if it is possible to divide the sub satellites, as can occur in QU-24, through the matrix outputs.
Thank you
I’ve split this into a new topic.
There already are several threads on this topic, latest was: Qu-16 active subwoofer integration
If you only need to duplicate LR using the Aux Out may be the most simple solution, but that may also be done using an analog split. None of the Qu mixers provide a crossover function and general recommendation is to use some dedicated external crossover if the (active) subs/tops do not already include one.
Using the GEQ or PEQ may work in some situations but does not replace a proper crossover (due to phase issues etc.).
