Hey folks!
Here’s what I want to be able to do:
Sub-mix drums to a group, so that they can be processed/parallel compressed as a unit,
Rest of band goes to another sub (group,) so that pans follow main panning, (pan following main pan is important for both drums and rest of band.)
Both Drums and Band sub-groups go to another sub/aux/matrix, which is then processed as a unit (Mastering comp/parellel comp on main band mix, overall eq, etc.) <—this group to LR bus/mains.
Lavs go to a sub group for feedback control, then to mains. <—NOT processed in the band sub group. (Important to retain gain-staging, headroom before feedback, etc.)
Media channels (pre-show mx, video playback media,) go directly to mains.
As near as I can tell there isn’t a good way to do this currently. IE, in my mind, the obvious solution would be to sacrifice pan-following-main pan, use a stereo aux path for drum sub, then assign that aux path to a “band” group, while assigning the rest of the band to that group directly. Problem is, you can’t send an aux path to a group, only input channels and FX returns. Matrix would be my next choice: You can send both AUX paths, and sub groups to a matrix, but then I lose my master fader functioning as my master fader. (IE the matrix has to be the master.) …which means I also have to burn another stereo subgroup for my media channels.
…and maybe I should be posting this in feature requests? It seems like it would be useful to be able to send auxes to a group for exactly this scenario; or, and I realize the infinite feedback potential here: groups to another group.
I suppose in the meantime, I could just create scenes that bypass the compressor on mains for non-band stuff. …but then there’s also no crossfade on that, so it’ll be somewhat obvious in the slight shift that happens between in and out.
Thoughts around this?
