Surface input peaking, with no input??
channel 57 on my T-112 (the physical rear input on slot :sunglasses: , without anything plugged in is peaking constantly. when listening to it, it makes all digital noise, especially when you hit the select button or any button it makes digital ‘beeps’. i have rebooted several times and no luck.
i updated the firmware last week to 1.70…
any suggestions?? im lost.
iLive T-112
iDR 48/24
i mean inout slot ‘A’ on the surface…
iLive T-112
iDR 48/24
Hi Stephen
This sounds like you could have a possible hardware fault on your surface.
Please contact A&H technical Support who will be able to help resolve your issue.
https://allen-heath.helpserve.com
Regards
Sam A&H
i see something like this when i have different firmware between surface and mix rack …
after upgrade to new firmware on both surface and mix rack everything is ok and normal[:smiley: ]
