Surface inputs / Split up on desk
Hmm.
Running a singback show with a showgroup using in-ears.
Backing material on a Macbook connected to the T-80 surface input RCAs.
Have splitted up my T80 desk so that one layer is inputs for FOH, the second layer is same inputs but for IN-ears. Problem: The surface RCA-input doesnt split so that I can use it separately for FOH/inear. Checked the Gang functions and everything without luck :S
Any thoughts?
BR
Daniel
Daniel -
Select the channel you wish to use for the “split” (iem) and then select its source, which would be “surface”, then “A”, then the number of the rca (5,6) in question. If you are using the 2 rcas as stereo input, perhaps set up a stereo channel for your purpose. Save the scene!
Tim Tyler
Detonator Sound
Richmond, Va USA
T112/48 R72/32 laptop iPad Dir-815 Dante
