Surface showing what scene has been triggered from midi
When triggering scenes from i.e. Qlab, the surface should show somewhere witch scene that has been recalled.
You can set it in scene settings. While scene is loaded you’ll see the banner in the top left corner.
Which setting? I cannot see any indication on the screen on the console except when I’m on the Scenes screen, or if I have the Scenes widget loaded on the right.
I tried Scene Options/Display Last Recalled on or off, does not make a difference.
If you trigger the scene with the go button on the desk there is a “play” sign on the scene currently loaded/recalled. But if you trigger from something external like midi, then there is no indication of witch scene that’s currently active… This should be fixed.
