If I don’t care about local audio in/out at the surface can I use a standard network connection between mix rack and surface? I’d like to use the ACE port an an iDR-16 to connect it to another iDR over ACE for a FoH/Recording split. I don’t need local in/out on the surface for the iDR-16 so I’d like to just connect it via the network port. Possible?
You can connect a surface to a MixRack using network-to-network cat5.
You will get metering and control but as Lieven says, no audio (local i/o or PAFL). If your MixRack is close to your surface you could plug your phones into that instead (or run a long cable?).
You don’t say what your second (record) iDR is doing? has it got a surface? or if it has ACE in port-B. The system is designed to split signals between MixRacks port-B to port-B 64 channels bi-directional. Port-A is designed for the surface i/o connection and includes PAFL and TB. however 30 channels are still available to send to another ACE device. The second MixRack could receive 30 channels from your iDR16 port-A ACE BUT only via an ACE card fitted to its port-B (you cannot take external sync from port-A).
Leon A&H UK. Please do not adjust your set; normal service will be resumed as soon as possible!
I don’t need PAFL at the recording surface. The iDR-16 for recording will be racked right beside it so I can use it for the PAFL.
I currently have a T-112, iDR-32 with Port B ACE, xDR-16. I’d like to use the 2nd port on my Port B ACE card to split to a recording console (the iDR-16/R72) and have a Dante card in the Port B on that surface. Then I’ll be recording over Dante to 2x JoeCo BBR-Dante boxes.
can i connect from T surface network to Pro series network, to make 2nd control instead of using laptop?
