Surfaces loose conection
When i use the I-Live editor the surface loose connection . Y connected the network port of the IDR to a D-Link router to use it from my laptop and each time I open the Editor and start a new connection the surface loose connection in the PC and the Physical surface too .
What are your IP settings.
I am having the same problem with my iLive editor(windows 10) causing the surface to disconnect. Did you ever find the answer to your question.
Thanks so much
Charlie
