Synchronising Dlive, Macbook with Reaper & utrack24
Hello folks :slight_smile:
This is my first post here, so welcome everyone.
So lately i have started to tour with some band. They use Cymatic U-track24 to run the playbacks, clicks & SMPTE.
U-track happens to have MIDI OUT port and I just wonder if my idea will work.
Long story short, I wanted to implement MIDI track in Utrack, and connect it to my Dlive & my macbook with Reaper.
What I want to achieve?
I want u-track to change my scenes in dlive and also start simulteanious recording and backup tracks to play from Reaper (via DVS & Dante card)
Is it possible to do that using TCP/IP?? U-track have only standard 5pin midi out port, and it happens to be on the stage.
Do I need additional Computer?? or is ther a midi to ethernet converter to connect with control port in CDM??
Sorry if my question is a bit confusing, but I hope someone has an answer for that :slight_smile:
Have a good Day
Hey there. Have a look at bomebox. I think this device could solve your requests.
Yep BomeBox is the correct interface for that unless you want to just use TCP midi driver over the network, and have reaper spit out the commands that way. I’m pretty positive you could accomplish that with SWS or just build midi triggers in to your tracks. (Say you wanted a panic button or something, SWS might be useful for issuing that kind of command.)
…you don’t technically need the Bome Box if you’re running the TCP driver. I rely on TCP for communications between dLive and Live Professor pretty consistently. It’s been rock solid for me.
One thing that is nice about the Bomebox is the midi translator: If you use that you don’t have to build your specific messages in Reaper, you can use, say a particular note on/off and have “Midi Translator,” turn that in to a specific dLive command.
I use Osculator to do that for certain circumstances. (In that case changing OSC messages like “/thingy1/go” to dLive commands, but it also works for straight midi.)
Good luck!
Hello thanks for your answers. I Will check this bomebox for sure.
I Just need the utrack to be my main midi device as this device have onli midi out and I can program the Command in it sp when the drummer Will hit play it will start my shows. Can i do that?
Yes, it should work. You just need to be very specific with the midi messaging.
Issuing scene recall commands should be straight-forward, (program change,) but if you wanted to do, say, a particular fader or send level, (I’m thinking delay swell/feedback moment type programming,) That is a super-specific NRPN message you’ll have to program on the uTrack, which might be a bit more complicated. It all depends on how deep you can go with message formatting ON the uTrack.
Thank You for Your answer :wink: It gives me more to think. Is it possible to use utrack only as a midi starter for reaper and then reaper will send scene changes to dlive console??
what is the goal of this?
send a midi command from the console to reaper for the start then the DAW can send what ever you want
You missed my point. I need Utrack 24 to activate the whole chain as this playback machine have only midi out. So when the drummer hit play on it I need it to send a midi command to Reaper to start, and then reaper should send scene changes to the dlive console.
yes I miss your point and still do
what is your problem with sending MIDI messages to the desk?
uTrack has network out, dLive has network in… still don’t get it
Hey :slight_smile:
Steffen Let me be more clear. I just want utrack to start the midi session in reaper. As reaper session is my backup session if utrack fails, I need Reaper ( NOT utrack) to send commands to change scenes in dlive. I am new to midi so this is why I am asking maybe stupid questions :slight_smile:
you can send what ever is needed from Reaper
Reaper can send everything what is possible in MIDI protocol
there is no need for Bome Box or other things since Reaper is able to send MIDI over TCP/IP
and this depends on the computer used
https://www.allen-heath.com/dlive-home/dlive-documents/
Correct me if I am wrong but I do need a bomebox to get standard midi signal via din-5 and connect it to dlive CDM48 TCP/IP Midi port (ethernet).
Here I have attached a simple diagram with signal and command flows
Nope…Network
Networ means everything is in a network
so whatever you want to send to start something you can send it directly
btw. LP has a cue list exactly for this
and one more thing
you need to synchronize your backup to your playback
How can i send midi from utrack directly to the reaper if they are 70m away?? The only gateway to do this and not to spend more money on more cables and interfaces, etc is to send it via dlive tcp/IP midi. Plus starting with midi shouldn’t give me a synchronisation?? or the latency would be to big??
your problem will be a different one…
Reaper and Liveprofessor will not work with low latency at the same time…
Dante will not work with low latency at all in this setup
to use this for Playback would be no problem but it will not work for insert processing
so it would be better to cancel this
but reverbs could be doable…
Can your U-Track send MIDI Time Code?
if yes then you can synchronize u-Track and Reaper
if not there is another possibility
you can record timecode into your U-Track session as audio data on one track (make shure it is not clipping anywhere)
and play it back into your dLive and route it to a Reaper input with a Tie Line
the Tie Line will add around 0,7ms of latency
Reaper can sync automatically to that time code
I’m not shure but in this case it should start automatically when TC(from the u-Track) is started
the time to lock on the TC from the u-Track could be a problem, you just have to test it
@Steffen R, it would be very logical for the dLive to work with the MTC, but not ??‍♂️
Thanks Steffen :slight_smile: That cleared my mind a bit.
Timecode is not a problem as we use it for the lighting guy and it’s already implemented in Utrack track nr 8 and i’ve already thought about it as a synchronising method… I am not sure about what utrack can do with Midi unfortunatelly.
I will have to make deeper search about that. If I use utrack only tu start the session in the reaper that should do the trick and then You are right - I don’t need bome box.
Geting back to the live professor and Dante.
if I setup Live professor on another computer will I be able to make latency enough to insert plugins (at least some of them) via Dante card?? or i will be able only to use it for reverbs and Delays?? ( which in my case are 90% what i need )??
Will I be able also to record multitrack simultaneously on another computer via dante?? Or it’s just a russion rulette?? :slight_smile:
Reverb and Delay is save to work in Live Professor
insert processing depends on what latency is tolerable at your task
DVS has a given latency and LP adds a bit as well (and the plugins of course)
I guess it will be more than 10ms
the smalles value I tried was 15ms
and I ended up with about 20ms for save use with reverbs
it is possible to get lower latency with dedicated DANTE Hardware like the Yamaha or Focusrite PCIe Cards or the RME Digiface DANTE
these do not use the DVS, they use dedicated ASIO or Core Audio drivers to realise lowest latency possible
one of the main problems you will have is the loose of the phase coherency of the complete mix since every plugin chain adds latency
so you need to process all channels or add a delay to the channels not processed with plug ins
and this can be a real challenge in a live environment
since most of us agree,
that the internal processing with dynamics and equalisation is very good
and the most needed improvement is better reverb
above problems are not that relevant to the average user
recording and live propfessor at the same time should be no problem if you split it from the playback and not using to much processing in LP
or too many tracks to record
Hey :slight_smile:
Steffent thank You for this huge explanation. Yes definetly the biggest issue is reverbs, and delays in Dlive. Well Issue is a hard word, but for what this console is it could have better FXes ( that remind me about digicos FXes).
External PCIe Dante cards with box to run it is unfortunatelly out of my budget. But I will check. Still I though that Dlive architecture will compensate to everything that would be inserted on the channels even if this is external processing via Digital link of course. i guss I misread it :slight_smile:
thank You all for help. As soon As the Covid ends and I start to work again i will try tu bilt this connection and will let You know how it goes :slight_smile:
