T112 + IDR32 Hard reset
Hi anyone can plese tell me wo to make a Hard reset to those Allen & Heath parts?
On the events list they had different time and date .I think they did not work and cause boot failure of the Rack IDR 32.
Thank you
JC
Hi jc:
Check out the attached document.
-Mark
CPU-RESET-NON-modular.pdf (357 KB)
Thanks Mark. Hopefully I won’t need this, but it is good to have for future reference for our system.
Thank you Mark.I’ve tried this before, but did not resolve.
The main problem is on the IDR 32 Mainboard, it as some jumpers inside like Desktop mainboard, to make several operations, but I did not have information enough.
The time clock is not the same with the surface, and I can made the Firmware update with no errors, but communication with surface or with PC only, I can’t suceed.
Thank you any way
Best regards
JC
I’m having the same issue. I tried to reset everything by flipping all the switches up and doing the boot and then down for the reboot and everything is still there. Nothing changed.
Hi Barrett,Have you achieve a resolution to our Allen Heath problem ?
Best regards
JC
