Hi All, I have a T112 that appears to have a failed touchscreen SBC as it is not powering up or showing any sign of life what so ever. The power connector has 24v present so it’s not that.
Has anyone else experienced this or know what might stop the touchscreen SBC from powering up (other than total failure).
Have you tried hooking up a VGA screen to the VGA port on the back of the surface? I’m assuming that the channel LED’s still work and that the surface can still control the Mixrack. This would be a major inconvenience, but you could still use the board with iLive Editor or a remote VGA screen until a new touchscreen arrives. It shouldn’t take a good technician more than a day or two to install the new screen.
Hi Mark, it’s not the touchscreen it’s the computer (SBC) that runs the touchscreen that is the issue and therefore not controllable via a monitor and keyboard.
Hello Dymond
It s look like a hard SBC failure that we already met few time. To fix it on the T112 and R72 that got the same trouble was to change the SBC PC…need to call my friend to get the exact reference for this PC master controler that you can found on the web.
Waiting for a hardware solution you should run the Hide software “DL5000” that is masked in the firmware data. Launch it in the same connexion way as the ilive director ( same IP parameter) then you computer will take place of your touchscreen completely synchronised with the surface button. If you have a touch screen Pc that should be even better than the ilive touchscreen …specially under sun.
Anyone got any tricks to get an SBC to boot? There is 24v at the power connector but the thing will not fire up. I’m guessing the thing is fried but any hints or tips?
A quick question to anyone who knows the Fujitsu SBC?? I know that there has to be a BIOS setting which you change to tell the SBC to start after a power failure automatically. If the CMOS battery has failed, could it be that the board is waiting for a start command? Maybe there are pins that can be shorted to tell it to power up? Then if it boots, you could see the output on an external screen, and press DEL to get in to change the BIOS settings using a USB keyboard??
I have the same problem as above powered up ok before battery replaced and was able to get into BIOS, now after battery replaced sbc will not power up( fan not running etc)
I have the same issue. All fans spin, and I get a white screen, but the rest of the console is inactive and I get no output on the External vga. My SBC is the first one in the PDF. Any ideas?
If you are still interested - yes it’s easy, I used acronis true image. Booting from usb-drive and made an image. But I think other tools like norton ghost will work.
I also replaced the old fujitsu with a newer fujitsu board - recovered the image to a fast and new CF card. Works fine. But unfortunately it was in 2017. I can remember, the system (ubuntu) named the ethernet interfaces not eth0 and eth1 but eth2 and eth3 - he knew the old interfaces and incremented. The A&H Program (I think it is a java app) was hard coded to eth0 I think. So I had to rename the ethernet interfaces to eth0 and eth1. Then the SBC reconnected fine to Surface and MixRack.
