Hi there!we are using t112 surface with idr48 and now getting one more t112 surface to make a FOH/MONITOR system,what are the options for that using one idr 48?which card is the best solution,we are offered a m-es-v2 but is there a cheaper solution,greetings buric
you need a idr-rack to have access to your idr48
greetings from hamburg
Hi buric
I am afraid the iLive system does not support 2 surfaces connected to 1 mixrack at present. You would need another Mixrack to make this a valid system.
Please read the information in the reference guide below that should help you understand the system concept.
Regards
Sam A&H
