Tagging LF, HM ... In EQ display curve
For me it would be helpful, if the eq- curve points beeing tagged with LF, HM and so on, in de EQ Screen. So I can directly push the correct EQ softbutton I would like to change.
Thank’s a lot
PS: @keath there are many feature suggestions here, but is there still a plan for an major update?
@Smalldevel
The PEQ band points are all coloured to match their LF/LM/HM/HF indicator and just touching any of them on screen will select the correct band on the surface as long as ‘PEQ Band Follow Screen’ is turned on in the surface preferences, but your suggestion is noted.
and yes - although there is nothing imminent, there will be a V1.6 feature/major release for SQ at some point.
I color marked the band select Buttons with little Stickers ?
