DLive is on latest firmware. When i recalled shows where talkback is assigned to aux4 ( to send over dante) there is no sound/metering on the aux. i haven to deselect the aux in the talkback section and then select again. After that, talkback is again going to aux4 ( and i see signal on the meter) I have 2 shows with that configuration and they do both the same. I will try with one of my default shows to see if i haven the same problem
I never had that problem on earlier firmware. the other sends to aux ( who are not send to dante) are ok.
anyone had the same problem.
Were the show files created and/or last saved prior to the firmware update where the problem seemed to start? Have you corrected the problem and then resaved the shows under the new firmware? If so, does the problem persist when you load the updated show files?
show was existing en saved before upgrade firmware. I have to investigate further if problem is corrected after reassign and save show was all in a hurry but i thought that it didn’t. i will test and comeback here
I have no idea if “resaving” the show files on the current firmware version will correct the issue or not. I just think it is a logical thing to try. Please let us know the results if you do try this.
