TalkBack Softkey Aventis Solo
Hi, Adrien here,
I’m new to the Aventis family.
I’ve assigned a talkback softkey 17, which sends to all auxes — that works fine.
Now I have a question:
Is it possible to create another softkey (e.g., Softkey 18) that switches the talkback to only the in-ear mixes (not all auxes), so I can switch between talking to everyone and just the in-ears during the show?
Thanks in advance!
Unfortunately, unlike the DLive, the Avantis doesn’t have talkback groups. I don’t know if the scene recall filter system has granular talkback settings in it. That would be my recommendation however - see if you can save a scene and set a recall filter to block everything EXCEPT the talkback settings. If you can, then you can save a scene with the talkback going to ALL mixes, and a second scene with the talkback only going to IEM. You can then assign the scene to a softkey to load whichever talkback scene you need at the time.
ok thanks for the tips maybe i hope a MAJ in the future to have mutiples groupe asignement for talkback
Maybe another suggestion in a different direction:
If you have two input channels left, you could also consider using them for your talkback.
To do this, patch your talkback mic to both and route them to the respective mixes according to your requirements.
You can then the mute buttons of both channels assign inverted to your two TB softkeys.
One advantage would be that you could even dose the talkback differently in the individual mixes and, if necessary, use the full channel processing, e.g., Comp.
One disadvantage would be that you cannot use Dim PAFL.
hooo, i see nice direction
So my TB in input local 1 and an other chanel with TB2 patched in local 1 too
after i asign the first TB to my Sofkey 17 with all wedges and the softkey 18 to the TB2 asign to in-ears aux only.
What a nice idéa
So many thanks
