On my SQ6 is there a way to adjust the volume level of the talkback mic in the aux mixes? We just started using this and everyone says the mic is blaring in their IEMs. I cannot seem to find any way of adjusting this while still using it as intended.
Would you not just adjust the gain/trim to a comfortable level in the Talkback settings screen?
If you need more fine-grained control, you can skip the dedicated talkback button and use an input channel instead. Then you can control your level individually for each mix. You can still use the Talk socket, just patch it to the input channel of your choice. If you want to still have an easy toggle, just assign a soft key to the channel’s mute.
