is there any way to change the ratio of the tap tempo, to say 1/4 note or 1/3 its way to hard to tap 75ms delay
You can use the encoder knob to dial the exact delay you desire within the tap tempo FX screen itself.
yes understand this but would like to be able to tap in time,
75ms was just example
Exactly what delay period is too short for you to tap? I have not found I need anything shorter than I can tap.
I like to run some delays on 1/2 beat or 1/4 rather than on the beat - used to using Yamaha fx and desks so just trying to duplicate on A&H
Use two hands and do the tap with the upbeat hand?
The board and/or you would need to know the BPM to work with the concept of ratio (1/2, 1/4, 1/8, etc). So take out your calculator app and do some simple math
60 000ms / BPM = 1/4 notes in ms so for example your song is 90 bpm : 60 000 / 90 = 667 ms for a 1/4 note delay
That also means that, when you tap to the beat, you already have your 1/4 note delay so you probably mean something faster like 1/8 or 1/16 note so just divide the given time on the tap delay screen by 2, 4 or 8 for 1/8, 1/16 and 1/32.
Just to be sure you get it because I noticed you mentioned ratios for beats and notes; 1 beat = 1/4 note so 1/2 beat is a 1/8 note and 1/4 beat is a 1/16 note.
thanks, I do understand, sorry just mixed my terminology, unfortunately I’m using this desk live so a calculator would not be useful, as stated before its possible to change note value on a Yamaha and I was just trying to find out if this was possible on an A&H
simple, tap the delay time you want that would equal double… then dial in half that amount
sinple…
I know exactly what you’re saying. There is no way to tap in a 16 note delay much over 100 bpm. A tap multiplier would be a great addition.
This is something I requested some time ago. The ability to quickly and accurately double or half (and possibly use thirds as well) delay times would be really useful I think. It was certainly a feature I looked for when choosing outboard delay units when the desks were all analogue. Also showing BPM as well as times would be useful.
Also, there is no way to dial (it would be a slider I guess) or type in a delay time on an iPad - tap is all you get.
I was given a set list with BPM on it, before a gig recently. The only way I could preset some delays to save in my library was to use a metronome on my phone - it ought to be easier than that.
