The 44.1k vs. 48/96k argument
While I get that arguing over which sampling rate is better or worse is great fun, I think all of recording comes down to individual preferences and getting past the technical issues so we can get into our comfort zones of creating. If I have been successfully working, selling & creating music at 44.1k for 20 or so years, and have a back catalog of 700 + tracks that sound great, it doesn’t really matter if someone tells me 44.1k isn’t as good. Prince & Dianne Warren used their cassette recorders at the piano to jot down ideas. Of course we know cassette is outdated but for them, it is their comfort zone of how they get their creative juices going. For me to come in and say they are “doing it wrong” is arrogant and missing the point. So it is with people claiming 44.1k is archaic and obsolete. There is no obsolete when it comes to our workflow & process of creativity. There’s only tools & method.
I bought a CQ 18T thinking it would be a great evolution to my process. I received it, only to read the fine print that it doesn’t work at 44.1k. I was so disappointed!! Then I had friends tell me I could spend a couple of weeks and convert all my files and my entire system to 48k, just so I could use the CQ.
I don’t think I’ll do that. I found a Presonus mixer that can do either 44.1k or 48k with the flick of a software button and it makes me wonder…#1, why are we arguing over sample rate choices in 2026, shouldn’t technology give us the freedom to choose our process? and #2, why would Allen & Heath choose to miss out on a huge slice of the musician market that still uses archaic 44.1k (and possibly a tape recorder!) It literally would mean more mixer sales and if Presonus, Soundcraft, Behringer, QSC and Midas can all do it, why isn’t Allen & Heath’s R&D capable? I would think it could be done with a firmware update and a trimming of some fat here & there. The fact remains there is a large portion of beatmakers, musicians, and people still making CD’s that would eat these mixers up, if only they were versatile enough to work at the lowly, insignificant, unusable, outdated 44.1k. It’s exactly like QSC making the Touchmix 16 & 8 and not creating them to be audio interfaces. Huh??! If they had done this, I think they would have made audio interfaces obsolete, but, I think sometimes the geniuses of design really miss the “street beat” boat.
The various A&H digital mixers are designed primarily as a “live sound” mixing console. 44.1 really doesn’t exist today in the live sound ecosystem. It is primarily only found in recording studios. As such, there is little reason for A&H to support 44.1k on any of their current console models.
Some other manufactures are using “off the shelf” processing chips and if those chips support 44.1k natively, they can add that support to their console pretty easily. A&H has decided to use FPGA chips which they basically have customized from scratch. Therefore it would likely take more resources to make the system support 44.1k than takes other manufactures. Given the almost non-existent need for 44.1k in live sound, I think they have decided to spend their time, energy, and money in supporting other things/features. I personally would agree with that decision, but obviously it isn’t going to make everyone happy.
Is this just for playing back pre-recorded music? I just feed it off my phone.
You could easily find that out by reading the OP’s post.
All current A&H consoles operate internally at a clock rate of 96 kHz, and both their hardware and software have been specifically developed and designed for this purpose.
A conversion to 48 kHz presents no issues, as the clean factor of 2 involves only relatively simple calculations.
However, conversion to 44.1 kHz is far more complex due to the necessary resampling, and thus carries, among other risks, the potential for various artifacts that may be more or less audible.
And A&H rightly steer clear of any such unnecessary measures that could
a) compromise their targeted, first-class sound quality and
b) increase their outstandingly low latency figures.
In this light, the decision of A&H not to support 44.1 kHz strikes me as a logical consequence.
If it is it only for recording at 44.1, some DAW (at least the one I am using, Reaper) can do resample recording.
I never use it ( I record at 96khz always) but I have tried and it is working.
My Cq is set to 96kHz, the project setting is set to 44.1 and no pb.
44.1 was never meant to be a general studio audio standard. It was just devised for home CD audio.
There’s no reason to stick with 44.1 in your studio environment.
If you look back at the majority of studio sample rates for early professional digital formats, you’ll find a lot of early digital was 32-50khz, but rarely 44.1.
Frenchie is right… Reaper (and I’m sure others) will resample on the fly, and even run tracks with multiple different sample rates without issue. So if you really want an entire project in 44.1 all the way through, you can still do it.
Another example of a sample rate which is basically obsolete is 88.2. Unless your mastering house specifically asks for it, don’t bother with that rate, either.
I always use 48khz. Today’s outlet for recordings mostly is video sound for me, which is 48khz anyways. When publishing music to Bandcamp, I usually provide 24/48, and I myself like downloading music in that format instead of 16/44.1. So, for those people who still produce CDs, they may find that a good DAW will resample the final mix in good quality as one last step, while working on the mix in the DAW in 48 or even 96khz makes perfect sense.
48khz vs 44.1 does not make such a big difference in disk space consumed, and disk space for the needs of audio still is inexpensive even with the memory crisis.
If you’re really into high end recording, however, you might not be too happy with the default A&H preamps/converters. Not that they’re bad. But the RME audio interface gear is better… and will run at 44.1khz then, if desired.
Yet streaming services have cut the revenue stream for most musicians doing recording, so this one conversion from 48khz to 44.1khz might be something one has to live with, as well as with default console preamps. At least, we have consoles with built-in recorders that are sounding good for live shows and that are affordable, like the CQ and SQ series.
I understand the reasoning behind 48k for live sound, and I’m not arguing against that.
My point is more about workflow.
A lot of us have years (or decades) of projects, templates, sample libraries and mastering chains built around 44.1k. So even if 48k is technically fine, being forced to switch between rates adds friction to an otherwise smooth workflow.
It’s not really about “which sounds better” — it’s about flexibility.
If the CQ is already doing internal DSP at 48k, fair enough. But having optional 44.1k support at the USB/audio interface level would make it much easier for hybrid studio/live users like me.
Can’t believe this is still being argued.
Who? Everyone I know in mastering is running at 96k and has been doing so since about 1998… There was a brief period during the late 90s when HDCD processing was around, where 88.2KHz was used so the final could be dropped to 44.1KHz with minimal artifacting (and simpler math) for CD production, but it’s basically an obsolete sampling rate.
Not to get confused here… all modern A&H consoles are doing 96khz only internally. Including the CQ series and the new QU series.
The integrated USB interfaces and USB/SD-card recorders can be set to use 48khz for recording.
Most audio nerd dudes I know love to discuss why 48khz sucks and everything should be 96khhz. Me and myself, I am doing everything 48khz, which includes mixdown of recordings in Mixbus Pro, even though my studio system could run at 96khz.
44.1khz never has been a thing in pro audio.
44.1 kHz has never been a thing in professional audio? That’s quite a statement!
44.1 kHz has been widely used in professional music production for decades, and plenty of commercial sample libraries are still sold at 44.1 kHz today.
I understand that 48 kHz is standard for video and many live sound applications, and that’s perfectly fine. But the entire audio industry doesn’t revolve around those workflows.
Many of us have years of projects, templates, recordings and sample libraries built around 44.1 kHz. In my case, I’ve worked at that sample rate for years, and there’s no meaningful audible benefit in moving everything to 48 kHz just to accommodate one mixer.
My point was never that 44.1 kHz sounds better than 48 kHz. It’s simply about flexibility and compatibility. If you prefer working at 48 kHz, great! But having the option of 44.1 kHz would be useful for those of us who work differently.
I’ve since found Allen & Heath’s explanation that the CQ doesn’t have sufficient processing headroom to support 44.1 kHz conversion, so I understand there’s a genuine technical limitation with this hardware.
That’s unfortunate, but it’s a very different argument from saying 44.1 kHz has no place in professional audio.
I am not a pro audio producer, but I don’t quite see where the CQ sits in your workflow.
I use it to record live shows and then import all tracks in reaper, and never use the mixer downstream from that.
Are you using it as a studio audio interface? I mean, the ability to work as a usb audio recording is a feature nearly everything has these days, but it wouldn’t be what I would get a CQ mixer for.
