The MIDI Control app does not convert QU-5 MIDI messages to Mackie Control Protocol
I’m trying to control the faders of Cubase Pro (14 or 13) with the QU-5, but I can’t find in Cubase the virtual MIDI ports generated by the MIDI Control app for the Mackie Control Protocol! I only found the QU-5 MIDI ports…
The messages received from the QU-5 MIDI port are (obviously) always the original ones generated by the mixer (CC), not converted by the MIDI Control app to the required protocol.
I am using Windows 11 and MIDI Control V2.30.
Has anyone found a solution to this problem? Thanks.
I am writing below what I was advised by tech support and worked for me.
The problem is the new Windows MIDI driver that does not allow the DAW to see the virtual MIDI ports generated by Allen & Heath’s MIDI Control app.
We have seen reports of MIDI control breaking on Windows 11. This is from a service pack update that Microsoft has rolled out. More info in the article below.
We have found a temporary workaround by typing a couple of prompts in to Windows terminal. However, this must be actioned every time that the computer is booted.
  • Open Windows Terminal as an Administrator (“run as administrator”)
  • Type “net stop midisrv”
  • After that completes, type “net start midisrv”
Also, there is a strict order in which this needs to be actioned. Please follow the steps below.
  1. Allen & Heath Midi Control needs to be running
  2. Midi service needs to be running
  3. Midi service needs to be stopped
  4. Midi service needs to be started - this seems to allow midi service to enumerate virtual ports provided by the Allen & Heath Midi Control app
  5. Allen & Heath Midi Control needs to be stopped
  6. Allen & Heath Midi Control needs to be started - this seems to be necessary to restore MIDI data transfer from the QU-5 (in my case)
  7. Launch Cubase (in my case)
  8. Load or create multitrack session
  9. DAW control works bidirectionally between Cubase and QU-5 (in my case)
Hope this will be useful to someone.
If there are problems with the MIDI service, it could be worth to link to Microsofts MIDI Team.
Useful links regarding the new MIDI service
https://microsoft.github.io/MIDI/
