Tie line & direct out points
I assume a Tie Line from an input will come post A/D but pre the preamp-modelling?
Will a Direct out set to “post preamp” come pre or post the preamp-modelling?
Is “Post-LPF” a typo that actually means “Post-Filter”? (The filter can have HPF and LPF of course)
There is a block diagram in the manual on page 137.
Take a look at it, you can see where the tapping points are in the signal path. The “Post Preamp” taps the signal before the Deep Preamp.
The tapping points of the tie lines are not drawn in, but the tapping point for them is guaranteed to be directly behind the ADC. Perhaps A&H could add this to the text field “Input Patch”.
And yes, I would say that if you look at it, “Post LPF” is the same as “Post Filters”.
I would add that Tie Lines are taken pre Digital Trim, whereas Direct Outs are always post Digital Trim.
