Tie Lines vs IP direct out
Hello folks,
A quick question:
Tie lines is basically a Direct out Post Preamp correct? The global direct out settings obviously will not apply to the Tie lines, what about the direct out level for the single channel?
Cheers
Direct out and tie lines are always separate, direct out settings do not influence tie lines. tie line is the pure preamp signal, and is before the first possible direct out point which is post polarity and trim, as well as width on stereo channels.
Sent from my iPad using Tapatalk
