toggle Alt View
I use the “Alt View” button quite a lot.
Sometimes I have to go to the controls window and change that Alt display between those three view options.
I`d LOVE to simplify that switching process between these different views by :
SIMULTANEOUSLY turning the rotary control knob while the AltView button is pressed, toggling through these three view options.
What do you think?
greetings
Pit
+1
Yes, this would be handy at times. I sometimes want to toggle between DSP CHannel and SocketID. Usually have it set at “DSP channel” and then if I quickly want to see what socket it is assigned to I go to the I/O page and look for that channel. But that can be confusing if there are multiple assignments. So a way of seeing either with the alt view button would be handy. I don’t use the dB Value much.
But its not at the top of my wish list
Mike
