Toggle Send to Mix via Midi
Hello folks,
It would be nice if the On/Off option, available in the routing section of a chanel, could be controlled via Midi. Then a integration into Companion would be possible.
Right now only the send level can be controlled.
Greetings from Germany
Julian
If you do not require a large number of channel to mix on/off options, it is possible to save each option as a scene with only that option change active, the recall the scene by MIDI. Not perfect but should work, the Avantis I use is in our church so can’t try it right now.
Thanks for the idea. We also thought about this workaround, but since the sends should be controlled individually, that’s not really an option.
@ben.morgan Is there a chance to get this function integrated in one of the next updates?
