At this moment when you are working on some gain staging using the output of a compressor, the selection of the touch and turn know doesn’t follow if you move between different types of compressors or if you are going from a channel to a group etc. ![]()
You need to select (touch) the parameter first to change the parameter.
There are different ways to change compressor parameters. And these follow the selected channel if you like.
