Transfer from ILive to D Live
Hi everyone!
We just purchase a DLive system in order to replace our ILive. Is it humanly possible to transfer shows among them? Or whatever other data that would save me to do the whole shebang by hand?
Thanks a ton!
We don’t have a dLive yet, but everything I’ve seen tells me that the answer to your question is no.
There is too much that is different between the 2 systems.
You should be able though to re-create your show files using the dLive editor before you install your system is you have a solid understanding of the configuration that is going to be setup. That way you can hit the ground running.
