Trouble with daw
So I’m having a trouble gettin the SQ5 work as a daw contol with studio one. I have downloaded, extracted and installed the DAW driver for windowos. If i understand correctly it should work by usb conection (have tryed cat5 also). i find very little settings for daw in studio one but i figured to try to add an external device / new control surface And match with the midi channel i set in the mixer (channel 1). But nothing happens… I’m out of ideas. Could anyone here help?
I had the same problem a few months ago. Here’s the solution.
https://community.allen-heath.com/forums/topic/daw-control-driver-v1-60
What exactly did you do? I have alredy dowloaded the drier v1.6. Or were you trying to imply something else from the link?
At least to my knowlage everything seems normal until i go to edit the new control surface and it’s emty… it dosn’t show any parameters to assign / edtit (whatever you call it)
