Hello! I’m not sure how to keep this succinct - I’ll do my best. We own an SQ6 and use it in our theatre. We run Qlab for show control. I can successfully control the SQ6 from the SQ Mixed app on the Mac and an iPad. I’d really like to be able to send simple commands from Qlab to SQ6, such as mute / unmute and a few fader levels. I have watched every A&H video on YouTube & Facebook (thanks A&H!) and they are great, and I am a long time MIDI user, so the concepts are not new to me, but after many hours of trying I cannot get Qlab to change anything correctly on the SQ6.
My efforts have included:
-I have read the SQ MIDI documentation and understand that it requires 4 MIDI messages from Qlab to control it directly, however:
-I have downloaded and installed A&H MIDI Control 2.0 and am using the CC Translator setting to simplify the messages I need to send (per videos I have watched and the PDF that came with the program). I have tried the Mac connected to SQ6 via USB AND/OR TCP/IP (via a router), and with both methods A&H MIDI Control app seems to recognize the SQ6.
-I have used MIDI Monitor app to snoop on my MIDI messages, and as far as I can tell, I am sending the right messages to CC Translator Inputs from Qlab. Screenshots attached showing both connection methods and the output in MIDI Monitor.
-The MIDI channel of the SQ6 is 1 (which puts DAW Control on 2, which I am not attempting at this time). When I send a message from Qlab to CC Translator Inputs on MIDI channel 1, note number 0, velocity 1 (in an attempt to MUTE IP1 of the SQ6), nothing happens. When I send that same message to MIDI channel 2, I do get a reply message from the SQ MIDI Out, but still nothing changes. The screen shots show this as well.
-All devices are on the same subnet through the same router using Ethernet cables - no Wifi - or using USB directly. Again, SQ Mixpad works reliably via this setup, so I know the connection is working.
-I’ve even purchased a Bome Box and tried using that as directed, and everything sets up fine, but even so I also cannot get that scenario to work either, so I must be doing something wrong.
I know this is a complex topic with lots of moving parts, and explaining it over email is difficult. I’m doing my best to explain the situation!
Thanks, Jake
