Trouble with Qu-16 and USB drives
Hi all I have been loving my new QU but I cant get Qu drive to work with any USB stick I Bought a brand new San disk 64 GB extreme USB 3.01 as its on the approved list and still no joy
First I tried a Lacie rugged 1TB drive I have and it just keeps blinking “reading drive” but nothing ever happens.
The new san Disk asks me to format it which I select but then it just hangs on " formating" Thats if I turn the qu on with the stick inserted
If I plug in after its on it gets stuck on " reading drive"… I tried to reformatting my new sandisk to fat 32 and still nothing…
It came as EXFAT
What am I doing wrong?
Thanks for any help
Tim
AFAIUI Qu reads & writes only FAT32 file formats & large USB & Drives may increasingly be formatted in ExFat (as you found).
I suggest your solution may be to format in FAT on a windows machine (this is selectable) and then reformat on the Qu
Of course its the same format standard but will be then in a fast Qu pattern
Anyway, try it & see.
AlanG
Formatting to FAT32 on Windows 10 is not supported for ‘larger’ >32 GB USB flash drives. However I have had success with a tool from the Verbatim website, the tool is called “SmartDisk_FAT32_tool.exe”. I have just used this tool to format a WD My Passport SSD (500GB) that was not recognised by my Qu-24,the drive is now seen by the Qu and I am able to reformat it using the QU format utility. I’m just experimenting with a multitrack recording, its been running now for 40 mins without any errors being reported, fingers crossed!
I think its probably the 32 gb limitation thats causing me trouble the San disk extreme does not support partitioning apparently and I can’t seem to find a 32 GB version any more… I did the reformat on a pc and still does the same thing
frustrating
Ill see if I can find a 32 GB one somewhere I guess? Unfortunately I dont have a PC at home or office… all MAC
Have you tried the Disk Utility app on OS X to format the drive to FAT32? Think that works with drives >32gb.
Well I guess the new San disk extreme 3.1 64 is not compatible… on the list I saw an entry saying it was but there is another saying no
I got a lacie rugged mini 1 Tb. And all is hunky Dory now
So the Lacie rugged mini seems to work ok but I have an issue Im wondering about that doesnt seem to happen every time… When I arm and start to record in multitrack I am hearing hard drive noises that actually come out of the mains… Doesnt affect the recording but its annoying sometimes it seems to go away other times like last night it doesnt. sometimes doesnt happen at all. at home Irun the left right out into a bose L1 mainly for vocals.
Dont get how the Qu would get noise into the mains from the harddrive… Any idea?
Thanks!!
Do you have the ST3 muted? That’s a known source of noise from the USB port.
Ah No I dont!! Ill check that out in about ten minutes !
Thank you, hope that s it!
