Troubleshooting dx32 dm0
I can’t get sound to output from the prime out 1 & 2. On the router the squares are striped. The sound does output from the dm0’s headphones. I’ve updated the firmware successfully. When I read about it there are instructions that include ‘then pair the dx32 with the dm0’ but I don’t think that’s a thing. My dx32 shows up in Director. Dante will play in Director but no main output including the striped boxe problem. Looking for help.
Very confused description. Dante should not be involved in any routing problems regarding DX32.
Can you provide a screenshot with the output patch screen?
Thanks for your response these are two pics
Could it be that your output card is located in slot 3?
That slot has the numbers 17 to 24. Indicated by the gray background…
I guess I’m not that smart! but persistent thanks for that a lot
that was a 5 second fix, I just kept watching various YouTube videos and getting hung up.
Could you please direct me towards the tutorial for building channel strips ?
Thanks again
What do you mean with that?
I need to learn how to add effect sends and inserts into channel strips
Man, you should start at the beginning.
Why do you need inserts, but you are not able to handle sends?
The desk has everything you require on board, without the need for extra processing.
Did you read the quick start guide? It answers these simple questions already.
What is your setup?
I’m reading the guide now. Thanks again.
