Tunneling MIDI over Ethernet
Any thoughts about providing drivers to tunnel generic MIDI iver the Ethernet connection to the recording software to allow iLive use as a general recording interface with MIDI recording?
iDr48/T-112/MADI
What do you want to do exactly?
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
If you want to get midi from stage mixrack to surface then you can do that already ( midi is tunneled over the Ace network from midi in to midi out both directions) - if you want to record that midi signal to a laptop then all you would need is a midi interface at the laptop end.
Cheers
Richard Howey
Audio Dynamite Ltd
It was the possibility of using the iLive as the MIDI interface I was enquiring about.
iDr48/T-112/MADI
Hi dburris
The iLive systems continuously send and recieve MIDI data, so yes you can use the iLive as a MIDI interface. Here is a link to exactly what you can control.
https://www.allen-heath.com/UK/CategoryDocuments/iLive%20MIDI%20Protocol%20V1.8.pdf
I am afraid we do not currently have a Mac or windows driver for use to convert iLive MIDI into a DAW sequencer via TCP/IP, though this is already on our request list.
Currently the easiest way is to use a USB MIDI interface with your computer (e.g. M-Audio MIDIsport) then connect the MIDI IN/OUT ports on either the mixrack or surface.
Regards
Sam A&H
