Ubiquiti Nanostation would not be read.
Hello!
i travel with the Ubiquiti Nanostation LocoM2. This is configured as an access point, and cannot do DHCP, so everything needs to be on a fixed ip. It works great with the GLD and the Qu boards, however with the dLive MixPad, I get an error on the top left of the First page stating “Wifi Network : Not Reachable”
I had access to another Netgear router around, connected that, switched ipad to DHCP, and all was good.
Kindly advise.
p.s. I was forced to update the iPad to OS10.x.x as dLive Mix pad needed OS9 or above, and have not since tested the M2 with the GLD or anything else.
Thank you.
Regards,
Sidhu
Sometimes it helps to fill DNS address with router IP in static mode.
ddff
