UDP/TCP Control
Is it possible to fire multiple UDP/TCP commands to multiple ip’s in one go with Custom Control?
Right now I have a button that fires one command to 1 recieving piece of equipment but would like to control an entire stack of amps with one button push so they all switch their preset at the same time.
Hi Mark,
You could do this with preset recall - set the CC button to be a preset recall instead, and then use embedded recall to create a stack of preset recalls, each with their own UDP/TCP command to each device.
Hi Mark, (great name btw)
Thank you for your quick reply and exactly what I was looking for, cheers!
