UFX - Dual Mono
I am running the UFX Plugins but cannot get Dual Mono to work… It passes the Left side but not the right even tho it shows both inputs.
TIA
FYI Just realized this is specific to the Vocal Tuner… I was hoping that it would allow 2 vocals to be tuned on one fx slot.
The RackUltraFX rack supports dual mono, but only some of the units you can load into the rack support Dual Mono.
As far as I’m aware the units that support Dual Mono use are Saturator and Amp+Cab Distortion. This should be in the Firmware Reference Guide Ultra FX appendix but it appears that it isn’t. We’ll look into getting that updated.
And careful with Saturator in dual mono if inserting it into 2 mono grps. In some cases it might bring the desk down. I was told the case is being investigated.
ddff
I’ve also tried using the Amp Simulator in “dual mono” mode and gotten very weird and undesirable results. I’m not sure “dual mono” is ready for prime time yet with UFX slots.
I’ve submitted a support ticket with A&H about my situation…
Something has happened to dual mono on the regular FX rack as well. It won’t assign properly since version 2.0.
Apparently I never posted again after hearing from A&H support in my Amp Simulator dual mono situation. Apparently there was/is a bug that affected the PAFL buss, but it shouldn’t affect other busses. I ran into the bug while I was setting up a DM0 Mixrack prior to installation, so I was only using the PAFL buss. Honestly I simply moved to using two racks for the Amp Simulators and never looked back. Therefore I can’t confirm if the bug only affected the PAFL buss or not. I really should go back and try the dual mono option again because I could free up a UFX rack by doing so.
PS - this was on 2.02.
Sounds like something to look forward to trying when 2.0.3 comes out (2.0’s issues haven’t affected us, so I don’t want to rock the boat with 2.0.2).
